vcIntProperty
Typed property that holds a value.
Parent: vcProperty
| DefaultValue | Integer OR None | RW | Gets or sets a default value for this property. Value None means that an explicit default value is not defined. |
| Type | vcPropertyType | R | Gets the property type. |
| Value | Integer | RW | Gets or sets the property value. |
| waitFor | object | Integer OR None value, Optional Keyword[waitTrigger = Boolean] | Blocks script execution until vcProperty.Value is equal to the "value".See moreThis function returns an awaitable task. It must be awaited. Parameters: value (object): Value that is used for comparison. When the value is equal to vcProperty.Value, the task completes. Optional: waitTrigger (boolean): False by default. When waitTrigger is True, the task will wait for the value to change first, before comparing it against "value". Otherwise, the comparison is done immediately and when the values match, the task will complete without blocking the script. Returns: Awaitable[List]: The task instance. When awaited, returns a list of event arguments that the event has been triggered with. |
| waitForNot | object | Integer OR None value, Optional Keyword[waitTrigger = Boolean] | Blocks script execution until vcProperty.Value is not equal to the "value".See moreThis function returns an awaitable task. It must be awaited. Parameters: value (object): Value that is used for comparison. When the value is not equal to vcProperty.Value, the task completes. Optional: waitTrigger (boolean): False by default. When waitTrigger is True, the task will wait for the value to change first, before comparing it against "value". Otherwise, the comparison is done immediately and when the values do not match, the task will complete without blocking the script. Returns: Awaitable[List]: The task instance. When awaited, returns a list of event arguments that the event has been triggered with. |
Example: Wait for Property Value
""" This example shows how to wait for a property value to change.""" import vcCore as vc comp = vc.getComponent() async def OnRun(): int_prop = comp.Properties["Integer_1"] await int_prop.waitFor(5, waitTrigger = True)
Example: Wait for Property Value Filter Function
""" This example shows how to wait for a property value to change if the value passes the filter function.""" import vcCore as vc comp = vc.getComponent() async def OnRun(): int_prop = comp.Properties["Integer_1"] # use the inline lambda function as filter await int_prop.OnChanged.wait(lambda x: x.Value > 5)
Example: Int Property Limits
"""This example shows how to set properties with limits and setting their values""" import vcCore as vc comp = vc.getComponent() int_prop = comp.Properties["Test_Integer"] int_prop.MinValue = int(45.5) int_prop.MaxValue = int(940.457) int_prop.Value = int(468.319) print (int_prop.MinValue, int_prop.MaxValue, int_prop.Value) #prints 45 940 468
